Discuss Thermostat wiring in the UK Electrical Forum area at ElectriciansForums.net
Hi, I want to install a room thermostat (Salus ERT20RF) where there was none before. I would like to
leave an existing APT mechanical timer in place. My question is can I wire the switched live contacts (from both timer and thermostat) in series to turn on and off boiler ?. Both units have only 4 terminals (live, neutral, switched live and earth). Many thanks,
Paul.
Reply to Thermostat wiring in the UK Electrical Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
Evening all, Have been asked to wire one of these into a heating system that has no separate control (or valves) for HW & CH. Customer is going...
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
