Discuss Thermostat in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
goldenmeadow
Hi,
I have a little thermostat... very basic... ( two metals theory.)
think it was orig a thermostat for a fish tank heater.
Im thinking of putting it into the circuit of a small heater, so it will heat
the greenhouse to 70 , then cut out.
Im wondering, should I wire it into the live... red, or the neutral... black ?
thanks for advice
will the thermostat be rated for the crrent you intend to put through it? i doubt it, and i also doubt that your thermostat will be designed for 70deg. if you dont know which conductor to inatll the thermostat into, then may i suggest getting a proffesional electrician in, because this shows a complete lack of understanding of one one the most basic rules in BS7671
better still, buy a heater with a thermostatic control built in.
Reply to Thermostat in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hi guys, I'm on a job where one of the storage heaters isn't heating up. it is a dimplex model FXL18N 2.34kW. There are two of these heaters in...
6K
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
