Discuss Thoughts on new builds........ in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Been to quote for some work today and the house is a new build.
Built by Linden Homes. At first glance looks good but when you stop and look a little closer you see several of the walls inside are not straight that there are big curves and deviations in them. when you look down on the accessories, there is gaps big enough to slide a 50p down behind in the middle due to the curvature... put a spirit level on wall to check for a tv bracket and on one wall i can put my little finger behind the level at one end as the wall is so warped.
They installed aerial points in lounge and master bedroom but told them cable is in attic, for you to connect an aerial... Linden dont supply one, but the best bit is that due to being in a low enclosed area surrounded by excavated mounds and other buildings, the signal is so poor everybody is putting up sky dishes but some houses cant get a line of sight, so no sky either!
Linden dont lay the back gardens anymore it seems, left them a pile of slabs and said for you to decide how you want it.
the most damming from my view is an outside tap, which is directly outside behind sockets, thought to myself a bit iffy... took socket off wall and behind the plastic back box in the plasterboard wall I can see the joint and pipe, so in the event of a leak or dodgy joint the water will be spraying into the back of the socket!
proves my point, never buy a new build house....
whats the worst thing you have seen on a new build?
Sounds about right. I've been on new build sites around London for the last 7 years. All the contractors care about is get it done as soon as possible. "Qualifications? Who cares just make it work."
I was first fixing new build flats before I was qualified. I had been working with another unqualified electrician for around 4 months and then thrown in the flats on my own. I had a decent supervisor who would keep an eye on me but the main contractor couldn't care less as long as I was giving them 3 flats a week he couldn't care less about how neat it was.
Yeh working on them I made a note to self ...never buy a new build...they are crap construction. Shower wall disintegrated no primary seal under secondary seal. Plasterboard literally taped together around shower. One screw per hinge on doors. Absolutely disgraceful. Working as contractor is worse. You finish the job tiler comes in takes off all the sockets you get to come back and put them on for free. Bad plans mean you put sockets on wall where told, oh sorry kitchen sink is going there, you get to come back and re-locate for free. And on and on it goes snagging 'til pension time.
Just 1st fixed an annexe [the size of a 3 bed semi] and all the stud work has no cross noggins, asked about it for wiring and was told not needed. :rolleyes:
I do a few new builds each year, but these are more one off private new builds and all done to a really good standard.
The big developments are just getting thrown up with the cheapest and quickest ways possible. Oddly they get are sold at the top end of the local market as well, it's not something I'd consider buying at all.
Avoid like the plague ............. anyway, I would be too expensive for that type of work ..................... all builders want are unskilled, cheap labour
Echo that totally. I do a few new builds each year, but they are one off jobs each time. My price and my standards are far higher than what the big developments around here are after.
Definitely don't pay enough considering how much they sell for. Last job I was on they were paying £420 for a 2 bed high spec flat, it was possible to do 3 a week but not the neatest work I've done to be honest. But they get what they pay for.
I'll let you know.
I've just bought a new build, after living in a new build for the last 30 years. House before that was a new build, and the house before that was an existing property, that the previous owner had attacked it with his trusty DIY skills, that cost me some pretty pennies to put right. Only had one problem with me new builds, which was put right by the builders.
My latest one has metal stud & track partitioning on the first floor, I'd preferred wooden stud work, but hey hoe.
I'd asked for the back garden not to be landscaped, so I could do it properly myself, as previous properties had bricks, scaffolding etc laid under the turf. Had to sign a wavier, to allow the NHBC sign off to go ahead.
Got a shed load of mastic, to remove from the bottom of the skirting, installed to achieve the pressure test, before we can fit the flooring. It also has some annoying trickle fans in 'wet room's', which will need 'adjusting', so we can sleep at night without the constant whirring.
If you behave yourselves, I'll post a pic of the CU etc.
i'dagree with that cross noggins are unnecessary. the are put in to stop the stud timber moving laterally. once the board is fixed, the board itsef serves that function.tin hat.
It does not auger well for a big nationwide building programme to provide 'affordable' homes. Personally, where there is a demand I'd favour offering grants to folk to renovate those empty older properties in some towns and cities. I'd then have approved pre-vetted contractors and tradesmen/women in a catalogue, renewed every year, for these folk to choose from to do the necessary work.
Reply to Thoughts on new builds........ in the UK Electrical Forum area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Have a single plug socket which has been working fine for years. It is behind a unit so nothing has hit it. I looked at the socket and can seen no...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
