Discuss Thoughts on this consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
I guess this is a flat and the MICC is the upstairs supply. Under ESQCR reg 24 the DNO must maintain an adequate earth. Having said that, an adequate earth to us and them are two different things. I maybe would get my micrometer out and measure their earth but again guess is they are equivalent to 5mm² an adiabatic could settle the adequacy of them. Ideally I would want to see an earth marshalling point and get rid if that BS951 clamp and have it in the MET/marshalling point. I am sure you wont have to bring out the big guns unless you get a jobsworth in the office, but if so elevate to the supervisor and
Well spotted Vertigen. Your correct there is actually a property above. So does it look like they have taken neutral from our first head and took a phase from head 3. I'm intrigued by what that box is next to our meter? And the link that looks to be between it
No seals on two of the phase carriers, I see and it's not long since the other one was done, so did the 'engineer' know about the other neutral.
The black cable goes to the Comms unit at the side, looks like the one below as used by B.G
Watch that earth bond when you take it off....for damage to the lead sheathing. If so, that could be used to get DNO involved, also.
I would get the DNO to take it off when they are sorting the other earth clamp out it is not worth the risk at any level of something going wrong
Reply to Thoughts on this consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Hello all.. I'm quoting for some work and would like change the type AC RCBO to a type A. Consumer unit is a castlec which I have not come...
