Discuss Thoughts on this picture? in the UK Electrical Forum area at ElectriciansForums.net
looks like SWA through PVC Conduit - not sure why you need the extra protection on SWA cable though!
Also if this is an advert it does not do much for their company!
And if the plasterer hadn't removed the plaster, all would have looked fine.
They may strugle to get sockets on those boxes unless they are deeep.
I hate it when people leave the stickers on the conduit - looks so DIY.
The purpose of this installation baffles me? You could even suggest it to be non compliant as BS 7671 does not recognise Reference method B as a method for PVC/SWA - It only has reference methods C, E and D if I recall.
Looking at it again, it could be a large T+E?
Its definately 10mm T+E, and they are extra deep backboxes by the looks of it. Looks like its a for cooker circuit and the walls are going to be plasterboarded (i hope). TBH i don't see what is so bad about it, the only thing i can pick fault with is its not 100% straight but seriously who cares if its getting boarded over. And also hes took too much pipe into the backboxes, and so yes may struggle to get the fronts on! I think using conduit is a good idea as it will help cable replacement (if needed) in the future. Wouldnt like to try and push 10mm down that like haha!
Well it doesnt benefit your company as such, and I certainly wouldnt put it on a company website etc, but you tell me how it doesnt comply with the regs or what is so wrong with putting T+E in conduit?
If it is going to be buried behind plaster board why use an inspection elbow ................why not buy a couple of 10p adapters and use singles........................come on even taking into consideration it's going to be behind some plasterboard, and if they are extra deep boxes I hope its battened out , as they are going to be using an awful lot of dab otherwise ......................... there is a good way and that way to do a job
Oh im not denying its a poor picture. Theres nothing actually wrong with the work he has done, but i certainly wouldn't be putting a photo up of it on my website lol
If I'm piping into boxes I'm going to use bushes etc to end the conduit at the box not in it so I could get the accessory on afterwards. I'd also make sure the conduit was square and plumb and that the right bend had been used, especially if I'm putting it on a website for the whole world to see
You tell me why its okay and you will answer your question.
lol, i think its ROUGH! I wouldn't or even consider doing that ever! I mean how long would it take to put a bush on! Im thinking they don't even know what a bush is!
Using reference method A and 70C PVC cable with a size of 10mm, the CCC is 44A. Now whats the problem? I know theres no reference method B, however, surely method A (conduit in a thermally insulated wall would give you worst case scenario? As ive said previously, im not defending the guy, the work looks crap and i wouldnt advertise it or do it myself but what is actually unsafe about the work?
Did some work at a well known bank last year and the main electrical contractors who we subbied to insisted all drops were in 25mm conduit so future maintenance was easy. We did use adaptors and the boxes were 47mm ones to take the adaptors. Even in stud walls we used metal boxes screw to pre-positioned noggins. I dont see anything wrong in running t&e in conduit, no different to putting it into oval really.
Nothing wrong with the idea, but you have to think why?
If wall is getting boarded then whats wrong with good old capping to hold it in place.
Its just that this attempt is a shambles, as theres no way they will ever get the accessories to fit as they haven't bothered using any adaptors/bushes.
OP come on give us the link to the company HA HA
Reply to Thoughts on this picture? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm adding American muscle's halo fog lights to my 2006 v6 mustang and am looking for a good place to connect the positive side to power the...
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket, I was gonna put the socket behind...
Evening everyone… I’ve attached pictures for your leisure.. so basically the customer does not have any RCD protection.. 3036 fuseboard is in...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Can anybody ID this brand, I've been sent the picture only, as another "electrician" has been and butchered it and tried to fit mk grid, couldn't...
