Discuss Threading conduit (no vice) in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
I forgot I had a small conduit job tomorrow and I left my conduit bender at work. This means I dont have any kind of vice to hold the 25mm galv whist I thread it.
Any imaginative ideas on how I can thread it without any kind of vice?
I have some clamps but no vice so to speak....
You can put a 90° set into the tube then put it through something to support it but essentially it isn't feasible.
If the site has a lathe , you might manage to hold it in the chuck.
Unfortunatly it's not a site, it's a side job for a friend.
All I have as options are a bench vice, some mole grips, pipe wrench and clamps.
Starting to sound like a scenario post from tbe trainee section haha
Grips will just wreck the tube you could wrap the tube with cloth and sandpaper then grip in the vice but this would be optimistic.
We have successfully done this once on a job by using an SDS drill bit shoved into one end of the conduit and then using the floor and your knee you can force the conduit up at an angle with the drill bit putting pressure on one end
This allowed us to thread 4-5 lengths on a job
Make 2 Vs out of some wood then clamp them in a vice. Not tried it myself but that's what I would do . I have metal V blocks that I made a collage that I find handy for clamping tube to saw it
Try and use a pipe wrench and wedge it somehow to keep the pipe from turning
Reply to Threading conduit (no vice) in the UK Electrical Forum area at ElectriciansForums.net
So I'm starting out a new rig and I'm fresh out of college with my level 3 without any experience and I think that I need to still have the...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
As I have retired now (really!) I have decided to sell my electrical tools etc. They include hand tools, hilmor galv. conduit bender 20/32 with...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
I've an otherwise small and simple job to do later, out of hours, fit an outdoor IP FSU for a small AC unit fed from an outdoor socket on an RFC...
