- Reaction score
- 322
Three phase boards and switchgear used for 480V split phase. OK or not?
Hi from a newbie.
I have already bought all the DBs and equipment for a major rewire and extension at my old farmhouse in Norfolk. I was expecting to have the existing ‘split-phase’ 240/480V supply (from antique overheads and a pole transformer) upgraded to ‘standard’ three phase. (There is quite new three phase HV at the pole – with one conductor not connected - which I paid for a few years back, but only the old tranny.)
Apparently it was a standard way of saving copper in rural areas after the war – having only two HV conductors, with the transformer delivering two LV phases 180 degrees opposed.
Despite my intial expectations the supplier will not share the costs of modernising this antique installation. So, being unwilling to shell out their quoted twenty-odd grand (!) I’ll live with the existing 2 x 20kVA supply.
My question is, is it OK to use standard switchgear and DBs, wiring only two of the phases, and leaving the third unconnected. I’m concerned that maybe standard modern equipment is not designed for 480V between phases.
There will be three sub-mains in different buildings. Since these will be used ‘one at a time’ I think it’s better practice to run both phases to all buildings, then arrange the final circuits to balance the loads across the two phases. I don’t want to run, for example, only phase A to the barn and Phase B to the house.
I have bought a shed-load of 25mm 4-core SWA for this purpose (wonderful EBay, Eh?). Clearly this cable’s fine for 480V between conductors, but what should be done when it gets to the downstream boards?
Elsewhere I have seen the cable terminated in a splitter box then run to two separate domestic consumer units. I think this is inelegant. I want to use my beautiful new Hager TPN boards, but are they certified for 480V?
And a further question: What are the ‘correct’ colours for marking up ‘split phase’ 480V? 17th edition is silent on this. Using two of the 315V colours feels wrong, and I believe potentially misleading. And what do you even call the bloody things? A/B? L1/L2? R/S?
Apologies for the long post. I didn’t have time to write a shorter one.
Cheers, Mark
Hi from a newbie.
Cheers, Mark
