Discuss Tilt downlight recommendations in the UK Electrical Forum area at ElectriciansForums.net
jackhammerJIM
Good evening all .
I have a large ceiling sloped at 42 degrees i need to install 4 down lights in the requirements are
LED
tilt to 45 degree
dimmable
45 - 60 degree beam angle
approximately 1500 lumens each
warm white
this is in the realms of a commercial downlight but it is for a domestic job
already looked at
jcc
saxby
illuma
photonstar
ksr
i have found this one by lumibright (its going to be expensive)
LED indoor lighting suppliers UAE | Spot Light | Lumi Bright - http://lumibright.co.uk/product/lumiindoor/Spot/Adrin/LB2019/403
Also this one but dubious about the quality and not enough lumens
13W COB 60° Directional Scoop Downlight | Dimmable LED Downlights | Commercial Downlights - https://www.leddownlights.co.uk/13w-rotatable-recessed-gimble/scoop-downlight-dimmable.html
fitting more than 4 isn't an option due to the placement of 2 huge velux windows
any more suggestions before i call lumibright on monday .
Reply to Tilt downlight recommendations in the UK Electrical Forum area at ElectriciansForums.net
Need to install some soffit lighting (downlights) into the soffit of a bungalow. The problem is soffit itself isn't 90 degree horizontal with the...
5K
17 x JCC FGLED6 Tilt fire rated downlights for sale. Model number JC94481BN. Left over from a job, I can't return to wholesaler as they have gone...
Steveyboy10
