Discuss Time clock controlling a ring main? in the Industrial Electricians' Talk area at ElectriciansForums.net
HI,
i may be wrong but i dont think theres any regulations preventing it ,never come accross it myself .i would be inclined to use a radial circuit to feed the sockets that which nead timed rather than a ring,sangamo time clocks are rated at 10a ,if you need to switch more than this you could use a contactor.
hope this helps
Right, let me explain properly....
What i've got is a job spec for wiring a circuit to supply 4 x 2kw Dimplex panel heaters, and the circuit being controlled by an electronic time clock.
I have a few ideas but wondered the best solution as its not really something I've come across much?
thanks
Heres a link ,because your switching a resistive load ,heres a expensive but efficient solution ,Watlow Ltd-Power Controllers ,it might seem like overkill but combined in a suitable panel with a digital time clock would provide a first class job ,use 4 of the single phase contactors,each on its own radial ,"fused" in the control panel which you can easyly build to house it all ,
thats what i would do anyway
Thats the way I would go also. Din rail time clock, four radials, a 4 pole contactor and a fused spur by each heater. Nice.
That sounds a good design,
my question would relate to the contactor.
Is it right that 4 x 2kw heaters all turning on at the same time would be right for the contactor?, as this is the switched load and not isolated load. 8000 watts divided by 230 volts would be in region of 35 amps, not taking into account diversity obviously as i dont know off top of my head and havent got book in front of me!
What's you feedback on this?, are these contactors designed for switching this type of load?, as i dont tend to use them myself.
Thanks Anyway!
Thanks Anyway!
hi ,
contactors are made to switch loads which are not isolated ,ie ,on line , diverserty is not applicable in this case ,as the heater would be either on or off, i would be inclined to use single phase contactors so each heater could be controled seperate.
have a look at the link i put in the earlier post ,it wouldnt be essential to go to these lengths ,any contactor capable of switching the load would do.
hope that answers your question ,or have i missunderstod what it is your asking?
Reply to Time clock controlling a ring main? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
Hi guys I am looking to add 4 additional sockets for a room that is being converted for a bed ridden person. The room at present has no sockets in...
