Discuss Timed outdoor socket supply in the UK Electrical Forum area at ElectriciansForums.net
Steve T
Hi
I’ve got a standard double outdoor socket that has been installed for some time, and I’d like to make the supply to it timed to run some lights in the garden in autumn/winter only.
I’m planning on using a greenbrook mechanical timer, which is rated at 16a resistive and 2a inductive. I will install this after the FCU that currently supplies to socket. However my question is:
I only need a timed supply for 2-3 months in the year, and for the rest of the year I would need constant power to the socket for lawnmower/pressure washer use etc.
I know this could be achieved by setting the timer to the constant ON setting, but is it ok the leave it like this for most of the year even though the timer will still be constantly rotating?
Thanks for any replies!
Thanks for the suggestion, but unfortunately it won’t work as I need the two socket outlets in the outdoor socket and those timer sockets only have one outlet. Would it be safe to use the hardwired timed though, as I had planned?
Reply to Timed outdoor socket supply in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Hi, I am a basic DIY'er, with basic electrical skills, NB, I can change a plug/fuse, change a ceiling light fitting, change a socket face plate...
Autumn is now here, it's that time of year where the clocks go back and lighting control moves forward. A time when UK customers with gardens want...
