Hi peeps, I have been using these 24 hour 7 day din rail timers over the last year or so.
It has a override switch which permanently switches on the relay. The problem I am having is that the relay drops out after 1 minute after the override switch is pressed.
The same problem occurs when the timer switches on based on the time it is set but drops out after a minute from the time it switches on.
I suspect it is a batch fault but Green Brook won't say anything direct.
Anybody else having the same problem?
