Discuss Tips from a pro..... in the UK Electrical Forum area at ElectriciansForums.net
The tip about NOT using Hammer action is one i learnt years ago. It destroys stuff very quickly .Anything "New build " will just fall apart if you use hammer ! I also only uses wood bits when drilling plaster board .Find the holes much better . BUT ..only when i am sue no cables or pipes !
beyond me. if in doubt, make holes with hammer.
How does that work theres 2 different size threads
Usually when I'm widening the hole the holesaws are same thread
I see there it men's starting off with a small hole
I'd normally be starting at about 50mm or the standard size for a basic GU10 and tho enables you to conform the cables are there
I'm not sure why you would intentionally drill a hole smaller than what you would need, but you would then use the bit you used as the pilot, and rather than having just a few mm as a lead you have as much as you want. Works on the larger and smaller arbors.
When stripping down a motor gear box assembly (or for any assembly with multiple parts and casings) take a dot punch, lightly dot each item with its corresponding part, (taking care to not damage any engineered surfaces) especially if there are multiple possible positions but the original position is crucial on re-assembly.
I post this because one of my less experienced team members has just stripped a gearbox assembly down to replace some worn parts. He did have the common sense to mark the parts but used a "permanent" marker pen, only to wash the marks off at the de-greasing station.
Thanks for the link , gonna pick one up, seen so many tools and gadgets since I registered her, I need to speak to the wife
Reason for drilling the smaller holes as I said was there's so many sizes and I didnt always know so drilled for the smallest standard GU10
Not involved in that type work these days
Good post
Shooting from the hip but how much if any of that can you do with a camera phone
Prob not much
I got into the habit of taking out the phone and taking loads of pictures when strioping stuff down and reassembling
Good post
Prob not much
Yeah, sure with modern technology we can take snap shots that can be very useful. However, in certain circumstances you are looking for 100% reliability, digital pictures can be accidently erased.
New posts
Reply to Tips from a pro..... in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
I find myself in the position of having to fit a few back boxes in to plasterboard. In the past for the odd one I just used a hand plasterboard...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
