Discuss TNS Earthing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
oldskoolbeat
Hi all, I'm a newbie here so be gentle :eek: :D
Anyway...Doing a rewire on a house and the incomer has the old soldered on earthing, couldn't even tell ya what size it is (maybe 10mm), all I want to ask is should I get this changed?
The cable looks in good condition and reading are all okay (cant remember what they are right now but they were good).
So should I get it changed or leave it alone???
Beat (nickname;))
Excellent forum by the way
keep up the good work ;)
the earth of a TNS arrangement are normally soldered on to the armourings. have a bit of a play and if you're worried get some more solder on there to improve the connection.
normally the supply side isn't your concern and a good result on Zs would suffice
Any thing the other side of the meter is their problem. If your measured Ze on their stuff is within limits go for your life. If however anything is in anyway loose or corroded call them up and say "FIRE HAZARD". It's really good fun!
forgot to say it's good to see people taking this duty of care stuff seriously.
the house i went in today will need a complete rewire! the guy who lived there before fancied himself as a bit of a DIY legend, i wish i'd taken a camera - it's by far the worst installation i've ever come across!!! :yikes:
Thanks for the replys Lads
It was just one of them things where I wasn't quite sure, if ya know what I mean.
Readings are good and the connection is sound, it wasn't till I had to write the size of the Main Earthing that I thought what size is that then....
Be glad to see the back of this job, going on a bit long now, what with a total of 52 downlighters downstairs without mentioning all the ones in the bedrooms and landings :eek:
Still its a job;)
Off to read some more posts, thanks again :)
Any thing the other side of the meter is their problem. If your measured Ze on their stuff is within limits go for your life. If however anything is in anyway loose or corroded call them up and say "FIRE HAZARD" It's really good fun!
I like the "FIRE HAZARD". bit to get the job sorted :D
A few years ago in my own house the company fuse holder had gone for a melt down due to a loose connection, it was still warm and smelly when I found it, I ditched the load and removed the fuse.
When they turned up to replace it the guy said that I shouldn't have removed it, and then replaced the holder live :rolleyes: one lot of rules for one etc.
"the earth of a TNS arrangement are normally soldered on to the armourings. have a bit of a play and if you're worried get some more solder on there to improve the connection."
On NO account should you attempt this. I used to work at the local electricity board and was trained to do this kind of job. You'd be surprised how quickly the lead sheath melts if you're careless with a blowlamp.
By the same token, don't fix an earth-clamp to the lead sheath either - tightened too much and well, you'll need a new earth-clamp at least. Notify the local supply company and let them sort it out.
putting a few drops of solder on with a blowlamp is a bit extreme
get a soldering iron, put solder on to iron, let a few drops fall on to existing connection, job done!
Reply to TNS Earthing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
Been asked to do some rewiring, and have said needs upgrade of consumer unit really Main question is regarding earthing - Zs reads at 0.45 ohms...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
2nd fixing some sockets in an office today and we were talking about high integrity earthing, I've not got a clue what the sockets are going to...
