Discuss To tie wrap or not to tie wrap. That is the question in the UK Electrical Forum area at ElectriciansForums.net
As others have said, real nice job. However, get your boss to invest in some G/Y heat shrink for the CPC on jobs like this. Looks 100% better IMO.
I’m not a fan of binding cores in miles of insulating tape , it looks very amateur imo
A bit of 4mm 6mm colour sleeve would look the bizz
Put RCD on other side and move neutral bar over too.
Bring cables in at top instead?
that is the schneider design, same as the square D boards. L busbar is cranked behind the N. makes you thing when fitting the tails .....L is on right N on left.
Reply to To tie wrap or not to tie wrap. That is the question in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
Re:Grid tied System. Could someone advise please on the following. I wish to install a 3 phase (input) Grid Tied system to my home (2 - 5kw). My...
Hello all! Newer house, original owner(Florida). no change to electrical system. Just found there was an outlet (GFCI) in the closet so I wanted...
