Discuss To torque or not to torque that is z question in the UK Electrical Forum area at ElectriciansForums.net
So if you cant find the torque setting are you telling me you wouldnt be able to tighten it up and would have to ask for help
No I'm not I would use my experience to see how tight the connections were, before boil in the bag Electricians and torque drivers were even thought of.
Couple of thoughts. One, never seen DNO using torque anything, just T hex and doing things tight!! You know when you tighten up, you need to wait and go back and may tighten again as the copper relaxes? Well with a torque you can definitely tighten quite a lot more. So clearly I have been over tightening (is there such a word?) for forty years. Although I have read and been told this can lead to catastrophic things (not totally sure what!) funny thing is, never happened over all that time. Agree with @The Ghost that MK sockets feel far too loose by their torque level. There is a lot more to terminating than torque alone. Such as dressing the cable and using 19 instead of 7 Strand for terminals etc.
There is some truth in your statement DW but far to controversial to post my reply
Pete we have to start torquing all terminations in the panel to the recommendation of the manufacturers speciations. It’s in the 2020 NEC edition which will be inspected by code enforcement
Interesting discussion, this.
If a torque screwdriver has to be calibrated, is this an annual thing?
Kenny Ken has a point.
If the driver is used once a week, for a CU change say, that's one situation...but if you do 5 a week, should the driver be calibrated more often?
I see a difference between "mechanical" calibration and "electronic" calibration of a MFT. The former has a mechanical wear and tear element that may not be applicable to a MFT?
I expect that most of you will know just how tight is right...and i am willing to bet that even if the driver tells you it's right, if you are in any doubt you will resort to just manually checking anyway?
Maybe you all tighten the terminals, tidy up, then give them all a wee further tighten before you go home?
Better tight than slack?
No point in exhibiting a test certificate if patently the terminals are too loose, imho...the buck stops with you regardless.
I know it's not quite the same thing but we have to torque up the hv/lv connections on gen transformers and our torque wrenches have to be calibrated once a year. One thing you have to remember is to set it back to zero after use. If you don't it weakens the mechinism and it will fail its next calibration.
Reply to To torque or not to torque that is z question in the UK Electrical Forum area at ElectriciansForums.net
Send your layout to PCBWay for instant production with just one click. Have you ever thought that when you complete the design on KiCad, you can...
I was looking for some advice on common wiring styles for stairwell delay lighting circuits. So I can figure out what has been done in the...
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
My customer read on many forums about people suffering to solve a problem with the above Land Rover with regards to a fault code known as P1260...
29K
B
Hi all, Looking for a bit of advice please... My Sparky is away for a while (unsure how long - family bereavement) but I need to get the...
9K
