Discuss Toggle switch wiring in the UK Electrical Forum area at ElectriciansForums.net
bdblue
Hi,
Any help would be appreciated! I am residing on a canal boat and the toggle switch which turns the engine off stopped working. Looking at the wiring - it appears both wires have disconnected from the switch. I have bought a new toggle switch but am not sure about the correct placing of the wires. It has connections stating 1 and 3 - which wires go where? the pictures in the links below show the new toggle switch and the one that is currently in place with the black and blue wire connectors disconnected.
Thanks in advance
Just connect a wire to each terminal, not important which way around. The wires should be fitted with ring crimps, don't just try and wind the bared wires around the screws.
What is the engine by the way?
it's that big noisy lump of metal at the back, just under where he stands at the tiller.
Reply to Toggle switch wiring in the UK Electrical Forum area at ElectriciansForums.net
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
