Discuss Toilet light not working in the UK Electrical Forum area at ElectriciansForums.net
I can think of several causes why the light stopped working, but wonder if anyone did any fault finding, rather than randomly start changing components?
First I'd check the switch? Next, is there an incoming L feed from the previous light on the circuit (fault could easily be at the previous light (or equally a break in the N return)?
You need something more than a neon screwdriver or non-contact 'pen' detector to check properly, these can be misleading.
The fan is probably one of the last places I'd look (other than loose wiring at some badly made junction if the fan was added at some point).
Me I would change the lamp first!!
Have you changed any light fittings or switches anywhere else in the property?
Also, turn each breaker off and back on one at a time, sometimes they can trip but still appear on.
Could it be the switch if the switch has three switches?
Sometimes you will find with a toilet that has been added/converted it is powered using a FCU (fused connection unit) from a socket circuit and not, as one might expect, from one of the lighting circuits.
Check at your CU (consumer unit = fusebox) in case there is something that has tripped, but also look around the toilet area for anything looking a bit like one of these:
https://www.NoLinkingToThis/p/mk-logic-plus-13a-switched-fused-spur-flex-outlet-white/13479
If so you might find it has a 3A fuse that blew with a failed lamp.
I presume you mean a 3-gang switch (one switch is for the toilet, the other two for other lights). Yes, certainly one switch can fail, or even something simple like a wire loose and fallen out of a terminal.
Bathroom light & fan in my house is fed via a switched fused connection unit from an RCD protected ring final rather than the non RCDed lighting loop
Reply to Toilet light not working in the UK Electrical Forum area at ElectriciansForums.net
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Whats everyone's take on this, turned up today to start a re-wire and yet again there wasn't any toilet on the job so we ring the builder and he...
6K
Customer has a toilet block with 1 inline fan currently doing 1 toilet only. Set up as follows...
Guys Need some advice please. I was asked last week to investigate a burning smell in a toilet turned out it was an extract fan one of 2 The...
