Discuss TP&N equipment rating in the Electrical Engineering Chat area at ElectriciansForums.net
TP&N voltage ratings for products, equipments etc are expressed alternatively as 440/250VAC or 250/440VAC (or 250/440 Vac etc), or in other representations. What is the "technically correct" format and in what standard/specification is it embedded? (is it IEC60050?).
Thank you.
I believe you are right, the International Electrotechnical Vocabulary IEC60050- part something should cover it, but good luck finding the section that covers it among the hundreds of parts. I would be surprised if it defined in detail the distinction you are making. It seems traditional to put the higher voltage first - eg 440/250VAC (though there are plenty of examples the other way round), and I don't think your last example with lower case is preferred to upper case.
if you are asking in relation to labelling a product, or preparing the documentation or user manual, it would be worth talking to the Notified Body doing approval for you, (if that's happening)
Cable specifications are usually of the form Uo/U or Uo/U (Um) and I see various references to that format being defined in BS7870 Part 4.10 2011. Where that gets it from is a good question but might be a starting point.
Thank you for your reply.
Reply to TP&N equipment rating in the Electrical Engineering Chat area at ElectriciansForums.net
Hi Everyone Thank you for accepting me into this group. I'm obvoiusly new to this forum so please excuse any mistakes untill I familiarise myself...
I'm not being stupid here. Not correctly, as in, not as the labels on the device says So, the situation is, I have a TP&N distribution board with...
Someone asked about abbreviations used here. So I tried to copy a list I made elsewhere: A/C Air Conditioning AC Alternating Current ACB...
5K
Hi folks, I'm not an electrician and don't intend to do anything above and beyond the standard DIY changing of sockets/lights etc but I have a...
47K
Hi Lucian. I hope you see this post that I said I was going to put up in response to your information. After what you said about being surprised...
