Discuss Track lighting for a kitchen in the Lighting Forum area at ElectriciansForums.net
I'm looking to stick some track lighting in my kitchen, downlights would be ideal but pretty much mean ripping the ceiling down and starting again so looking into surface options.
Does anyone know of any domestic solutions? I've fitted multi-channel systems before but they were all quite bulky and commercial looking.
Thanks for any help in the right direction.
I agree with @Leesparkykent that any track lighting system will look too commercial for a domestic kitchen, only exeption possibly with very high slopping ceilings. But if you feel compelled to put a track system i would check out the jcc range. Why do you feel you'd need to rip the celing down to do anything else, maybe a pic of the celing/kitchen in question and forum members could post suggestions up and maybe youll see one that ticks all boxes :)
i really like track lights, easy to install, easy to add more lights, point the light into needed direction. load them up with LED gu10 of your choice. Theres plenty of selection for track fittings to choose from. I often use knightsbridge fittings, value for money and do not look bulky at all. rather modern and smart.
thanks, il take a look at JCC.
forgive the terminology here but il try my best, 1/3rd way into my kitchen there is a steel beam that runs full height of ceiling void, plasterboard right up to it. the rest the timber that holds up the ceiling goes from plasterboard to floor above so i'd need to make plenty holes to drill through the joists to get cables through. i moved my light switch in the kitchen a few months ago and found how much of a pain it is up there, getting in from above is as much of a pig, means taking down a king size bed and lifting the carpets & boards.
amlu- thanks, il take a look at knghtsbridge aswell. i like the idea that i could easily add more lights after if i needed to.
The knightsbridge black stuff seems like it might be just the job, not too badly priced, T's and bend connectors don't cost the earth, it looks quite slimline, might see if anywhere nearby has a showroom and take the Mrs to see it, think we're onto a winner though. il throw in some led daylight GU10's from led hut and i think il be all sorted.
Reply to Track lighting for a kitchen in the Lighting Forum area at ElectriciansForums.net
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
