Discuss Treadmill problems again... in the UK Electrical Forum area at ElectriciansForums.net
So, for the 5A fuse at least another 4 one hour sessions. And the same for the 3A fuse. Remember to run it first for an hour 'off load' before each session of running.
Alas, I am not infallible so could be completely off the mark.
Static Zap makes some good remarks on possible causes. It would helpful if you could look at the commutator and brushes and compare them to the guide I pointed you to.
I admire your willpower to use a treadmill - I found them mind numbing.
There's a sparky right across the road, I wonder if he'd have a look at it?
It'll be a long while until I've done all those sessions, guess the thread will sit open though...
The treadmill is a lot easier to use if you can watch YouTube while doing it, just stick on my "watch later" list and hours worth of entertainment! Yes, I went that far to make it appealing! Great for when it's raining too, no excuse not to get some amount of exercise!
The brushes and comutator look smooth as far as I can tell, the brushes smoothly rounded where they've been wearing on the commutator. No horrible scoring/scratching like in some of those pictures, although I can't tell without taking it apart if the brushes have dug grooves into the commutator, like some of the other pictures.
I found these brushes 10 pairs of potentially dubious quality brushes, what am I going to do with the other 9 pairs?
Maybe so. The earth pin is part of the plug not its top.
To my relief I found out you can simply open the plug with a screwdriver and entirely remove the earth pin, that'll save a lot of hacksaw work!:tearsofjoy:
Now I just have to find a knitting needle to open those pesky shutters for the live and neutral to slot in! Thanks for pointing them out Big Clive!
Reply to Treadmill problems again... in the UK Electrical Forum area at ElectriciansForums.net
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Got an issue with gym equipment. ( I keep telling my wife I’m going to the gym, but she doesn’t believe me!) The gym owner says the circuit for...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
