Discuss Triangular shaped panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
It is frustrating that you cant plan the installation in PV*Sol yet, it will be a question for the manufacturer when I get to see them.....
segen's training for them was apparently appalling, full of misinformation.
Key points of info they must have got wrong being the number of bypass diodes, and apparently indicating that they would need solar edge to work, which is complete bobbins.
From what I can see they probably either split the square panel into 2 and leave the triangle as a whole panel, or split tha square panel into 4 and the triangle into 2 with the bypass diodes, which would give equal numbers of cells, voltage, etc between the strings of cells. There are no clues to this that I can see in the documentation.
Yes the training was a bit of a mess, trying to show off their design tool and weren't able to answer basic design questions about the triangle panels.
Hopefully they will have gone away and done a bit more background research into the panels so they can ask installers questions better.
Hmm.... I'm booked in for Nottingham later this week. I hope I won't be wasting my time.
Did you get anything out of it? I have a few fairly obvious questions I need answering which I'm hoping they'll be able clear up.
Are you going to be offering it yourselves?
There's always more empty ones than full ones left in the box isn't there! I mean, how hard is it to throw the wrapper in the bin?!!
OT - I heard today that the triangles are not handed and that the square panels are actually rectangular, interesting though, if a little pricey - bit niche I guess?
Polys : The 'Square' panels are based on a 7 x 8 (56 cell) module and the "triangular" 7 x 7 (7+6+5+4+3+2+1 = 28 cells) so they are not 'handed' both 156x156mm cells
Monos: The 'Square' panels are based on a 8 x 9 (72 cell) module and the "triangular" 8 x 8 (8+7+6+5+4+3+2+1 = 36 cells) so they are not 'handed' both 125x125mm cells
Still need to get my head around which inverters can be used with them, not sure they would make sense financially if you had to use solar edge.
any string inverter.
the cells are identical, the ampage is identical, the voltage on the triangular panel is exactly half the voltage on the square panel, so it's no different at all to having 3 strings of 20 cells connected in series in a standard 60 cell panel.
If segen really were saying they thought they needed solar edge, then they need to get some better trained technical staff.
what you couldn't do is to run a triangular and a square panel in parallel for battery charging or something, which is really where a lot of the ingrained folk memory of panels needing to have identical voltages comes from I think.
Went to Segen training this afternoon and it was very poor. Apparently you can model in PVSys by using the 'square' panel and replacing every 2 triangles with one 'square' one. There is only one triangle module available meaning the cell sub-strings run up-down or left-right depending which way you orientate the panel. This means it is almost impossible to design a system with good shade performance as sub-strings don't all point the same way. The panels made in China from unknown Chinese cells and the mounting system manufacturers have not yet said in writing they support them.
Reply to Triangular shaped panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
I spend a lot of time renovating vintage broadcast radios, military radio and test equipment. At present adding panels to our off grid...
TLDR - I have a system that is supposed to have optimisers fitted, but I am not sure they have been fitted. The detail: Back in March I had a...
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
