I have a 2-way wall switch that is on a circuit for a room. The switch does nothing, although it is receiving power and when switched it does correct on/off the power to the second terminal (so the switch is working).
I believe this switch is supposed to control an outlet receptical in the room. Several others in the house work like this. Also the switch and the outlets in the room and the ceiling light in the room are all on the same circuit (I tested).
Here's a video showing the problem:
View: https://youtu.be/SXmp2QmqUmk
All outlets work in the room at all times regardless of the state of this switch. How can I find the "other end" of where this wire is going without ripping out drywall. How can I get this switch working as it was originally intended to do?
