Discuss trunking in the UK Electrical Forum area at ElectriciansForums.net
J
justanoob
Hi All,
just wondered if someone could help i am installing a switch on outside of an internal wall upstairs so no more than 1.5m in length only putting it vertical so putting it in trunking but this is where im a lil confused. do i cut hole in plaster board ceiling for wires only or do i need to carry on the trunking above there as well if so where do i stop trunking and also i think im meant to seal where the cut is in the plaster board in the trunking with some kind of fire proof stuff but what is it and would i need to do this etc hope you can understand what im talking about and look forward to your replys.
no not possible to fish down wall as they seem to have put horizontal battons on the plasterboard wall so keeps stopping at there if you see what i mean. what about this sealing it with fire stuff is this needed ???
No offence mate but this is why you should have got work as an electrician's mate/labourer to learn the basics.
You need to learn about building structure and basic builders techniques . I'm assuming the battens you are talking about are called noggings, you have to drill through these with a wood bit, cutting a hole in the plasterboard which you keep and then making good with batten and packers then either skim with multi finish or filler. Then paint. You also should make sure your cables are run in the zones outlined in the OSG.
This is getting worse :hand:,we now have noggin the nob
ok derek thank you for your info but the customer has said he wasnt planning on lighting this part of his house so got it plastered and he said he does not want me chasing the plaster or board out etc thats why he asked for trunking which he is paying for so cant say no. can you give more info anyone plz.
Justanoob,
Are you qualified?? Just wondering..
The horizontal battens, don't suppose your talking about plaster and lathe? lots of wooden strips flowing horizontaly with plaster coated over the top...If you are then you can fish the cable.
scorino yes only just qualified tho so a lil cautious thats all i would rather ask n do it right than be called, anyway the way he told me was bearing in mind im no joiner he drilled woods direct onto brick vertically every 2ft and then screwed wood which im calling the battons horizontally every 200mm from floor to ceiling if you see what i mean then plasterboarded and plastered over top so im thinking not possible to fish cable am i right thinkin this??
if you have this problem just dropping a cable to a switch god knows what the rest of the installation is like
onions mod me!!
Typical customer: expects you to magically put a switch in the middle of nowhere without disturbing anything.
It seems odd he/she doesn't want the plasterboard holing and refilling to do it properly, which will end up invisible, but prefers an ugly strip of white plastic trunking permanently on display instead!
Reply to trunking in the UK Electrical Forum area at ElectriciansForums.net
I've come to a decision, I just cant do work anymore that involves mad stuff, for example today - 2 bed flat that's had fire damage, someone has...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
OK. I can already feel the eyes rolling I am working in a yard where we are having trouble with vandalism. There is absolutely no way of getting...
HI All - need to run supply cables from the drivers to the ribbons in a new build. Its an ICF so will have min 10mm of plaster plus finish applied...
This is a strange one, my neighbour is a bit mad, he had a largish extension built in about 2015, the builder attempted to do everything including...
