Discuss Trying To Identify Wires in the UK Electrical Forum area at ElectriciansForums.net
Putting in a new garage sub panel, but none of the wires pulled to the garage were marked. There are three #8 wires, 2 hot and a neutral. The hots are on a 2 pole breaker. If I turn the breaker on and test for voltage, the neutral should not be hot. My question is, can I remove one of the wires from the 2 pole breaker, turn it back on, and then identify the hot wire as A or B phase?
Yes, in theory, although depending on the tester, the capacitive coupling to the disconnected hot might make it appear live, or partially live also.
Please note that this is a UK forum and we have different systems, materials and working practices. We only have the one hot and neutral in domestic panels, and identifying cables etc is always done with the supply isolated, using a low voltage continuity tester or multimeter. Testing anything with the AC line power on, when it is not strictly necessary, is contrary to our safety rules. I would recommend that you switch off, disconnect the wires, ground each one in turn at one end and search for the grounded wire at the other end with a continuity test or low ohms range.
Many thanks!
It nice to know how America family gets on with the electrics over the pound , i need to find out whichs hot and whichs cold on wiring , over hear we call it line and line and cpc.
To you its live and nuetral and earth
and if you get electrcuted you will be burided in it ,lol.
Buzz I call it phase to phase and phase to ground when I’m measuring voltage. I can’t speak for other electricians
Mike did you get your wires sorted out ?
Reply to Trying To Identify Wires in the UK Electrical Forum area at ElectriciansForums.net
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
