La Poste
- Reaction score
- 126
Greetings.
I have a question, this has been puzzling me for a while.
If a put an earth rod in the ground and use it as my main earthing method and measure the resistance I find it to be 160 Ohms.
Ok, Assume there are no RCD's and a link is made between the phase/line and earth at the distribution board, a fault current would flow of 230/160 = 1.44Amps.
This would not blow any circuit breakers and effectively this fault current would flow to earth indefinitely.
Now assume the building is equipotentially bonded and so all metalwork is bonded together. Disregard parallel paths, assume we have plastic pipes for water and gas.
What sort of voltage would I get if I touched the metalwork in the house assuming my feet were wet and placed on the ground?
Is it a simple or complex mathematical equation?
The reason I am asking is because my friend lives in Asia and has an earth rod with no RCD protection at all and I am trying to work out the worse case scenario.
Any thoughts would be appreciated.
Thanks.
Thanks.
