Discuss TT earthing question in the UK Electrical Forum area at ElectriciansForums.net
loplug
I'm working on a Job where the earth is TT there is a sub main fed by 16mm twin and earth if I put a earth rod in at the submain position should I connect the cpc of the submain to the earth rod at the sub dB or just use it as a cpc and earth the sub board separately ?
Reply to TT earthing question in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Insulation test live to earth = 0.7 ohms. This is a long length of buried swa cable (approx 100m) from mains in to submain. Test done with live...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
