Discuss TT system eic minor point in the UK Electrical Forum area at ElectriciansForums.net
mhar
New circuits. Ra of 229 Ohms therefore the rcds are for fault protection by design. Zdb of 0.29 (10mm gas bond) so are the rcds classed as additional protection?
Put water with it...reminds me of a long time ago a team were putting in a gigantic earth rod. We used to put loads of salt and coke in the earth and then water it. We dug out the earth before hand and mixed it. One of the guys toward the end jumped on the "conditioned" patch and disappeared into the ground. At the time it was hilarious.
get 1 rod into the foul drain.that should bring the Ra down.:eek::eek::eek:.
wait hang on a moment i will be doing more TT jobs in london with the car charger PME situation.
so what do i need for this.. some 12 litre of coke and salt? and this makes the ground soft?
Reply to TT system eic minor point in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
On an EICR I found a 200 amp 3ph supply, TNS earthing (which looks original) and Ze of 19 ohms. No rods. No RCDs. L1 -> N was about 0.5 ohms...
