Hi All
Trying to do some digging on TT systems. With regards to TT systems, I have had different views/opinions on this stating that TT installations should have double pole RCD when it comes out of the meter so the installation is protected by RCD before tails enter in consumer unit. I also had other sparks state that as long as you have a plastic consumer unit and all circuits protected by RCBOs this meets the requirements. Are both views correct or is one incorrect. Any info and stated regs would be much appreciated. Thanks in advance
