Discuss Tumble Dryer+oven+extension Lead=pop in the Electrical Appliances Forum area at ElectriciansForums.net
Reply to Tumble Dryer+oven+extension Lead=pop in the Electrical Appliances Forum area at ElectriciansForums.net
My tumble dryer broke, an electrician put a new and stronger capacitor in, couple months later I realised that the socket on the extension lead...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
Hi all, I am here just doing some research. We have a tumble dryer with a moulded plug fitted. The appliance is approx 6 years old and we have...
8K
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
