Discuss Tv aerial question in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
Here is our aerial. Looks like it is from ours but just wondered if it was an important part didn’t want to call an aerial person if not necessary
looks like half the reflector has broken off. if the TV pic. is OK, then I'd not bother till the other half joins it ready for the scrap run.
the reflector reflects the signal back and into the coax that's connected to the box just in front don't know the full technology, but it just works.
You missed out the 'driven element' that sits in front of the reflectors... it's this that is connected to the coax (or 'feeder' as it's more generically called). This type of aerial is called a Yagi...
...just sayin
also the PCB Baun that coaxes a Balanced signal
(opposing phases signals)
Into just the core of the coaxial cable.
..Since the change over plenty of transmitters are kicking out more power , so may be of little consequence.
Birds perching on it may not have helped !
Reply to Tv aerial question in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
I have lost the use of my two loft TV aerials due to interference from the installation of foil backed dense foam insulation. I guess this is...
I have a known working TV and went to set it up in another building for an old chap. He has about 3 TV's already. I connected the TV to 2 seperate...
Hi everyone, I am new to the forum and wanting some advice regarding a tv aerial. I moved into my own flat and bought a tv, however when I...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hi, I currently have a Megger 1730 v1 which is fine for all functions except the 2 wire (L-E) no trip loop test, (no 3 wire loop test on my 1730)...
