Discuss Twin socket behing wall mounted TV in the UK Electrical Forum area at ElectriciansForums.net
IAmSparkytus!
I've got a twin socket behind a wall mounted TV but the bracket I have is so slim that the TV won't hang when the plugs in the socket.
Can you get some sort of fused spur which fits on a twin backbox?
I have come across a few new builds where they have put something like this behind the TV, its actually a floor box but the plug tops sits inside doesn't stuck out
https://www.NoLinkingToThis/p/appleby-1-1-gang-dry-lining-knockout-box-35mm/22772
A metal version of this might work if anyone can point me in the right direction! Anyone know if this is twin backbox size or different dimensions?
That’s 160mm wide and is wider than a normal double box.
A metal dual patress is also available at screwfix
https://www.NoLinkingToThis/p/appleby-1-1-gang-galvanised-steel-knockout-box-35mm/48234
Reply to Twin socket behing wall mounted TV in the UK Electrical Forum area at ElectriciansForums.net
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
Hi all. I'm currently building an island in my kitchen which will contain a gas hob. I've cut a trench about 60mm wide from the edge wall to...
