Discuss Two Electricity Meter in the Electrical Forum area at ElectriciansForums.net
banny07
Hi Guys, 4 Bed house I am going to rewire have two electricity meters. Customer want to install seprate consumer unit for upstairs on one meter and downstairs on the other one. Incoming supply is single phase with seprate cut out for each one.
my question is wheather it is allowed or not as I think there will be situation where supply from differant consumer unit will be present in switches in hallway upstairs and downstairs (staircase). Do I have to notify twice to bc? Kitchen extension and loft is new built. Any suggestion please? Thanks in advance
Is this going to be two separate properties/flats/HMO???
Keep upstairs and downstairs separate.
1 switch fed from upstairs C.U at the bottom of the stairs for the stairs.
And a separate switch fed from downstairs for the Hall / entrance.
It'll get confusing, as it probably already has, with Energy suppliers who won't recognise 2 meters at 1 single address.
They either need to get the supplier in to fit two an additional meter so it can be billed separately or fit a sub meter and the customer bills the tenant direct at an agreed price.
Both CU's are downstairs under the stairs seprated by partiton wall and have seprate doors for cu cupboard.
If it’s going to be two flats in the future, the customer should really be thinking about it now.
Is there two water supplies also, with no interlinking between the two? Two heating systems?
You’ll have think of fire breaks between the two properties, eg fire hoods on down lights etc.
If the customer hasn’t thought of these things now, it’ll be a huge upheaval later on
Reply to Two Electricity Meter in the Electrical Forum area at ElectriciansForums.net
