Wetroom Store - Network Wetroom Suppliers
Discuss Two mats one controller in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi
I am planning on installing two UFH mats,
One 9m2 the other 6m2, i have the one controller, (living room / dining room)
Is it ok to put both mats into the one controller?
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
mattg4321
Depends what the total load is and the rating of the controller surely?
Are you an Electrician Mark?
  • #3
No not an electrician by trade
The mats are 150w
The controller says
Voltage : AC230V
Setting range: 5℃~50℃
Limitation range: 4℃-99℃
Switch differential: 0.5℃
Protective housing: IP20
Housing material: anti-flammable PC
Floor sensor: rubber-thermoplastic NTC sensor,cable length is 3m
CE Certificated
mattg4321
If you're not an electrician and clearly you are struggling with this I'd strongly advise you get an electrician to connect this for you.
  • #7
Found this
FH-300 Thermostat
Voltage
AC230V
Power consumption
2W
Setting range
5℃~50℃ (factory setting: 5℃~35℃)
Limitation range
4℃~99℃ (factory setting: 28℃~32℃)
Switching Differential
±0.5K
Ambient Temperature
-5℃~50℃
Protective Housing
IP20
Housing Material
Self-extinguishing PC
Floor Sensor
Rubber-thermoplastic NTC sensor, Cable length is 3m
Current
16A Resistive
Temperature Limit Option
Yes
Keypad Lock
Yes
mattg4321
Theres no way each mat is 150w. They are different sizes for a start.
If there was a total load of 300w over an area of 15m2 it wouldn't be getting very warm at all.
Like I said before, get someone who knows what they are doing. I suspect I'm banging my head against a brick wall here though.
Charlie_
Or a nice warm floor perhaps :tearsofjoy:
He means 150w per metre
telectrix
Mentor
so total load will be 2250watts. most stats should handle this, but should only fit 1 floor sensor, . if 2 are fitted, they will conflict.
  • #15
Ok so i have pulled the wire i had in my wall from my last thermostat,
(replaced with a nest 12v)
I am going to wire up my new thermostat but the wires are not what i expected to be ( see photo)
So to wire up the thermostat what wires go where?
Grey (N)
Brown (L)
Black (switched live)
Green (E)
Reply to Two mats one controller in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Test Meter - Forum Sponsors since 2007!
Top Bottom
