Discuss Two mats one controller in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi
I am planning on installing two UFH mats,
One 9m2 the other 6m2, i have the one controller, (living room / dining room)
Is it ok to put both mats into the one controller?
No not an electrician by trade
The mats are 150w
The controller says
Voltage : AC230V
Setting range: 5℃~50℃
Limitation range: 4℃-99℃
Switch differential: 0.5℃
Protective housing: IP20
Housing material: anti-flammable PC
Floor sensor: rubber-thermoplastic NTC sensor,cable length is 3m
CE Certificated
Found this
FH-300 Thermostat
Voltage
AC230V
Power consumption
2W
Setting range
5℃~50℃ (factory setting: 5℃~35℃)
Limitation range
4℃~99℃ (factory setting: 28℃~32℃)
Switching Differential
±0.5K
Ambient Temperature
-5℃~50℃
Protective Housing
IP20
Housing Material
Self-extinguishing PC
Floor Sensor
Rubber-thermoplastic NTC sensor, Cable length is 3m
Current
16A Resistive
Temperature Limit Option
Yes
Keypad Lock
Yes
Theres no way each mat is 150w. They are different sizes for a start.
If there was a total load of 300w over an area of 15m2 it wouldn't be getting very warm at all.
Like I said before, get someone who knows what they are doing. I suspect I'm banging my head against a brick wall here though.
Or a nice warm floor perhaps :tearsofjoy:
so total load will be 2250watts. most stats should handle this, but should only fit 1 floor sensor, . if 2 are fitted, they will conflict.
Ok so i have pulled the wire i had in my wall from my last thermostat,
(replaced with a nest 12v)
I am going to wire up my new thermostat but the wires are not what i expected to be ( see photo)
So to wire up the thermostat what wires go where?
Grey (N)
Brown (L)
Black (switched live)
Green (E)
Mark, you can not use a 12v stat to switch 230v. You are giving me the impression that you do not have the electrical competence/understanding so please don't proceed further others on here maybe not so diplomatic.
the new thermostat i have is 230v,
The wires that came out of my old stat, the electrician (who fitted my nest) says is 230v so i used a 12v to power my nest for my radiators and heating the water,
I planned to use the wires that came out of my old stat ( see photo)
to power my new UFH stat,
Reply to Two mats one controller in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi Guys Got a job where property is set up with Honeywell evohome TRVs and controlled via central panel. They're having an extension done with...
I'm after some advice please, I have carbon mat underfloor heating throughout my bungalow, each room has its own thermostat and are fed via a...
I have 2 Mira dual valve vision showers. The remote control.for the Vision model has been discontinued, so I bought a Mira Platinum dual...
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
