Discuss two pin 16av to three-pin uk plug in the UK Electrical Forum area at ElectriciansForums.net
AoifeB
I have a treadmill with a two-pin EU plug and 16Av but my house needs an Ireland 3 pin plug, is it safe to get an adapter and voltage converter, if so where could I source that? I have only ever used appliances with 13Av in my house before so I am unsure if it is safe, advice much appreciated, thanks
What Voltage is the treadmill rated at?
You say voltage adaptor, if this an EU unit it should be 230v you need to check the specification of the treadmill to see what voltage it runs on, you also need to know which MCB (fuse) in your CU (Consumer Unit) the socket you are going to plug into supplies that socket run, a picture of the spec plate on the treadmill and a picture of your CU would help.
It probably just needs a high quality "travel adaptor", but as above, check the rating in the manual or name plate on the machine to verify it is for 230V and not more than 13A.
Thanks! Here is a picture of the fuse box and treadmill plug, the plug says 16A 250v
Can't tell which MCB supplies your socket circuit from that picture, why is one of the MCB's taped over?
The plug from your treadmill is three way as the hole at the top is an earth connection, need to see the specification of the treadmill and know which one of the MCB's supplies your sockets?
To be honest that CU looks long past its sell by date, I would hesitate to plug anything into it.
That is a rough looking board!
The plugs always say 16A, that is thier rating, but the equipment can (and often is) much less. Have you got a manual for it?
yes, the board has been around a long time :) I have a manual here which says 220-240v and on another page, it says to ensure it is in a grounded socket but I do not know what that would mean, thanks
Mike's summary is good advice. There are many sub-standard adaptors on sale that are dangerous either through having no fuse, no earthing or inadequately shielded contacts. You should choose one from a reputable UK / IE brand, equipped with both a fuse and an earth (aka ground) contact. This can be either two metal springs that grip the metal contacts along the side or a pin projecting from the front that enters the contact in the front of your plug. A proper adaptor will have sides that prevent you touching the pins of your plug when it is partly inserted. If it does not have these it is not made to the relevant standards and should be avoided.
It should look something like this:
Reply to two pin 16av to three-pin uk plug in the UK Electrical Forum area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi all, Hoping someone can shed some light on this, i have purchased a surge protector and it will not fit the power cables i plan on using. I...
Legends, need some advice. I am a 12v automotive electrician, but have had a side project building a concession trailer for my dad. We have an...
