Discuss Two post carlift single to three phase in the Commercial Electrical Advice area at ElectriciansForums.net
diditrain
Has anyone had any history of powering a three phase motor from a single phase supply?
Is there a preferred/best way of doing this? i.e.single phase to three phase inverter/VVFD, convertor or using capacitors etc.
Not my usual avenue, but I have had the question put to me, so I am trying to get a bit more knowledge on the subject.
No , It is a newish lift . It is the same set up as @telectrix , only supplied with single phase. Removed the three phase four poster for a single Phase five tonne two poster single phase , because of high top vans and heavier vehicles, also on price really.
You can use a vfd if the 3 phase motor is multi voltage I.e. 400* 220 delta.
Where in the world are you?
Do the manufacturers have a single phase set up?
Just to remind you that if you alter anything to do with the ramp controls, motors, limits etc that changes the original spec of the ramp then you become fully responsible for the safe functioning of the ramp and safety of its users including any inherent issues it already has. I would think very carefully before going down that route.
If however you fit an upfront 1-3ph power converter then you stay clear of the minefield of regulations that come otherwise, I may of course be teaching you to suck eggs here but as I don't know your skillset and field of knowledge it is worth just posting for clarity of what you could be getting into.
The only other thing I would note is if you are converting a single to three phase then the demand on the single phase will be approx triple that of running it across 3 phase to start with. I personally have never used a 1-3ph converter so I'll let others advise on that.
Another issue to be aware of is the control circuit / built in lighting, if any, may have been derived from 2 phases. That may need sorting out.
I think I will probably have a look at the job, but decline taking it on. I would like to get a better understanding of these types of installations, moving forward.
Could really do with some upskilling, I think.
Just to add that there is also the issue of insurance, most insurance policies that your average installation electrician be it domestic, commercial or industrial will not cover them for this type of work, I had to search out an insurance company that did this kind of cover and trust me it ain't cheap in comparison, if you haven't specified you repair, upgrade and/or design and build machinery controls to your insurer then it is unlikely you are covered, another reason to make the wise move to walk away.
Reply to Two post carlift single to three phase in the Commercial Electrical Advice area at ElectriciansForums.net
Looking to use this brooks Compton motor as a replacement in an electric cement mixer. can anyone tell me if it is designed to operate off a...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
I have a single phase stainless steel pasteuriser that has two control boxes attached to it. One box houses the control for the electronics and...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Hello, I'm new to this forum, we are in the process of converting into 12 flats all electric, no gas incl. heating, showers etc. An electrician...
