Discuss Two speed heater switch in an antique car in the Auto Electrician Forum area at ElectriciansForums.net
Hello and Happy New Year:
I have a 1950 Cadillac that has been rewired and updated from 6 volts to 12 volts. One accessory which did not get upgraded is the fan for the underheat seater. It seems to run well with a 12 volt feed at high speed.
The problem is with the 2 speed switch. It is a typical bolt on ceramic switch. When I run the fan on low speed, the switch gets red hot - like burn up the car hot. I have tried 3 different switches rated at 6 or 12 volts, and the result is the same.
Unfortunately running the fan on low is really desirable as the Cadillac throws so much heat on high it is stifling.
Would pulling the fan and having it rewired to 12 volts likely fix this issue? Is there an easier way? Pulling the seat and the fan is a pretty big job - so I's like to make sure it's worth the effort.
Thanks in advance for your advice.
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
plugsandsparks
Possible a quick way out is to use two switches in series as it looks like the switches are also resistors designed to drop the volts, as you have doubled the volts , if you double the switches it may work.
You must put the switches in series, i.e. live into first switch and then the output from the first switch is the input to the second switch and the output from the second switch goes to the fan.
Hope this helps
P&S
Reply to Two speed heater switch in an antique car in the Auto Electrician Forum area at ElectriciansForums.net
