Discuss Two Stage Pull Switch For Bathroom??? in the Lighting Forum area at ElectriciansForums.net
You could always just break the switch live from the light switch to fan through a pull cord with a neon and put it beside it, that way they'l know which is which
Yes, a second switch would be easy enough to fit, but I just wondered if there was already something suitable out there..
What about this:
https://www.amazon.co.uk/250V-Electric-Momentary-Pull-Switch/dp/B00LXBICOQ
Looks like a 3 position switch..
Depending on how this works.... You would have to have something like a T flip-flop for position 1 (Light), then another T-flip-flop for postion 2 (Fan) and then position 3 resets both T-flip-flops.
That's the sort of thing, but not sure how you would physically mount that...But at least I now know what they are called which is a step forward
Reply to Two Stage Pull Switch For Bathroom??? in the Lighting Forum area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
