Discuss UK Easy Fuse Finder Kit Socket & See ??? in the Electrical Tools and Products area at ElectriciansForums.net
T
TPES
Does anyone have one of these kits?
How usefull do you think this would be?
Worth looking at buying or a useless bit of kit?
Click this link to read more..... FFCB 200 UK Easy Fuse Finder Kit
Hi, I have one of these and the Jury is still out on how useful they are.
I think you have to spend time learning the best way of using it, it acts differently if held vertically or horizontally for example.
Single phase boards work best, three phase seem to be a bit hit or miss.
They are handy where you have to find if a circuit comes from a particular board though.
I wouldn't write it off, if you can get on cheap enough and you do a lot of Periodic Testing you will occasionally get it out.
Hope this helps
Reply to UK Easy Fuse Finder Kit Socket & See ??? in the Electrical Tools and Products area at ElectriciansForums.net
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
Electrical2Go - A Guide to Click Sockets: Which Is Right For You? Click Sockets Guide: Which is right for you? Click is a leading manufacturer...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Evening all, I’m looking to install an outside light as a spur from a socket on a ring main. There is already a spur from this socket supplying...
