richard9876
- Reaction score
- 0
When earthing gas and water service pipes do the 10mm earthing cables HAVE to come from the main earthing terminal (first tee) or can they come from a consumer unit that is connected to the main earthing terminal by a 16mm earth cable ?
What specifiacally do the relevant regulations say about this (my house was built in 2012) ?
I ask because Cadent recently changed the gas pipes in my street to plastic and they moved my gas meter nearer the road because the gas pressure was too low with the new thin pipes.
However they refused to earth the new copper gas pipe they installed inside my garage that connects my boilers to the new meter position.
They said the earth cable for the old meter position comes from a consumer unit after the first tee which doesn't comply with regulations and so they wouldn't earth the new copper gas pipe they had just installed.
Note there are three consumer units in my house each of which is connected to the main earthing terminal by 16mm earth cables which is why I have a main earthing terminal even though it's not directly used to earth the gas and water pipes.
On a wider note do you think Cadent are being reasonable or unreasonable as regards refusing to earth the new gas copper pipe in my garage ?
