Discuss Under cabinet LED lights issue in the Lighting Forum area at ElectriciansForums.net
Hi all,
I have a problem with two sets of 12V LED under cabinet lights. Set 1 is a set of 6 lights under the kitchen cabinets. Set 2 is a set of 4 lights above in glass cabinets. The problem is set 2 flicker/pulse every 20/30 seconds whilst set 1 is on and only when set 1 is on.
I have IR’d the 3 core to the junction box which is ok, checked the wiring arrangement and connected set 2 separately without set 1 connected which works ok. Only when set 1 is on does the problem occur, it’s very strange…
Wiring diagram here
Ideas welcome...
That’s a good idea I could try that, might be harder to implement seeing as I’ve just walked in to this new kitchen and didn’t do the work. If I had I would have done seperate feeds.
Not sure what you mean re induction?
Hi bud,what are the type,make,etc of the drivers and LED's?
You have a 300%+ driver for only 50% more lamps,which might not matter,but does depend on what is being used.
Agree with Des something to try, and without knowing how things are installed, make sure the 230v cables are not running alongside or near to 12v wires. Try another switch.
Reply to Under cabinet LED lights issue in the Lighting Forum area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I'm from Sri Lanka. We have installed LED Floodlights from two different Italian Brands (I can mention the names if wanted) on two different...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
