Discuss Under cabinet strip lighting, Upgrade to LED in the UK Electrical Forum area at ElectriciansForums.net
Does this flex just go up behind the cabinet to a connection on the top?what it appears that you have is 230 volt twin cable appearing from your wall into bottom of units,this should have a cpc for protection . as it doesn't i would advise getting a spark in to rectify this for you .
the fitting may be class 2, probably is,however surely a cable buried in a wall should have a cpc?Do we know the new fitting isn't class II ?
would you happily bury a twin flex in a wall at a depth of less than 50mm ?Why?
The cpc is not there to protect you if you drill through it although it has the advantage that the protective device will trip should you drill the line and cpc together.would you happily bury a twin flex in a wall at a depth of less than 50mm ?
the first post showed a twin flex feeding a mains fitting probably a class2 ,the flex appears to be buried in the wall ,IMHO this is bad practise, the t&e should have been brought down back of cabinet into a jb and connection made in there .that's allThe cpc is not there to protect you if you drill through it although it has the advantage that the protective device will trip should you drill the line and cpc together.
my first instinct last night was to say to the op chop off end of old connector and replace with new connector as i didn't think they were compatable, however i thought i would get slated for that so chose a different approach, but that's what i would have done in my own house
Reply to Under cabinet strip lighting, Upgrade to LED in the UK Electrical Forum area at ElectriciansForums.net
