Discuss under floor heating. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
BAZ
Hi hope some one can help, i'm looking for information on wiring under floor heating system, i know there is many system but i'm just looking for the basic's. For a example a five zone system.
thanks,
Baz
sounds like your talking water heating with electrical controls?? if so ive tinkered with a john guest zone system with manifold etc, what sort of information do you need? ive got a full instruction booket on the john guest range or google might be able to help
there are a few ways, NU heats water heated and thats a really simple. there are other ways of zones like installing motorised valves at each point.
controled via a clock or room stat or both!
john geust is a crap system never has the flow, NU heat can design you a full system if you send them a drawing/plan
Reply to under floor heating. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In July I moved into my new home with Schluter DITRA heated floors in the bathroom. The floor quit working in December, and my GC and a rep from...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi. I'm installing a wet underfloor heating system in my own house. What would you recommend as the best smart control system? I can hardwire...
Hi there I need your opinion on this one, I need to fix mat 18sqm (200w). Client instead of one mat bought 2 mats (12sqm)+(6sqm) one thermostat ...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
