Discuss Underfloor heating bathrooms- recommendations? in the UK Electrical Forum area at ElectriciansForums.net
Got two underfloor heating systems to install- both on timber with a tiled finish. Both bathrooms are around 2 x 2.
What systems have people installed and what recommendations have you got?
I installed some 'Warmup' purchased by my customer. No idea how he came by his choice. Was supposed to be installed on their insulated base, but customer didn't want to raise the profile of the floor. So dunno how efficient (if there is such a thing with this stuff) it is. Just installed on some plywood, on top of the chipboard sub floor.
The last lot I fit (which happened to be the first lot too) was just under 12m square and pulled 7amps when on and cycling - that’s expensive heating.
I would make sure that thermal boards are fitted though even if 6mm thick otherwise you are warming the wrong way!
Thermal boards nearly double the price of the job though!
My install was done for a bloke with 'loads of money'. Don't think he cared, if he was heating up the room below, just so he didn't get cold feet. Even had it installed in the shower enclosures. I did suggest just turning on the shower for an extra minute.
He also had wi-fi controller, so he could turn it on when he was on the other side of the world. :rolleyes:
my recommendation is don't bother. total waste of labour and electrickery. a pair of socks is much cheaper to fit and easily replaced without ripping floors up.
Difficult to make much of a mark up there. I feel much the same when I'm asked to swap perfectly good light switches for "brushed chrome screwless flat plate " or some such fashionable -------s, but it's work innit?
Reply to Underfloor heating bathrooms- recommendations? in the UK Electrical Forum area at ElectriciansForums.net
Hi. I'm installing a wet underfloor heating system in my own house. What would you recommend as the best smart control system? I can hardwire...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
A friend of mine wired a 10mm 3 core armoured cable to his shed before I got involved and wired it himself already. He wants make it an air bnb...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
