Discuss Underfloor heating fault in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
T
tiandrew
Hello, I have electric underfloor heating in our bedroom under ceramic tile. there are two systems wired to one touch screen stat, (1x15m & 1x5m) they were installed about 2 years ago and worked great for about 8 month. now the larger one does not heat up? i have tried wiring it direct to the stat without the other one and still nothing. I managed to test it with a meter and it is o/c (there is no resistance at all) i know it can be fixed but i dont know how. any advice please?
Finding the break is the hard part , specialist companies , or your floor supplier will have the equipment needed. It may work out cheaper than trying to do it yourself .
Have the tiles been disturbed in any way? Have you tried a cold tail to earth test to see if that is shorted?
Most likely suspect (bar damage) is the join at the end. We have replaced a few that had burnt out but this was due to damage and was under carpet.
depending on how its wired we use a couple of methods audio tracer puts a tone down the cable you can trace till it stops do this on both ends will find the break. or favorite is turn it on and use a infared hand held camera you will see the break through the tiles.
a company charges on average 2-300 for this. and they will fix it. to fix just use a butt through crimp.
usual problems cracked tiles where floor moved and ends the cold tail and final end as resu mentioned.
Reply to Underfloor heating fault in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hello Guys, I was wondering if any of you nice chaps could lend me some advice. So I have an open vented heating system with a 3 port valve...
Morning all, I'm about to embark on some home renovation and the kitchen is the first target. We are looking at making it bigger, all in the room...
10K
Hi everyone We have a little problem with a heating system on one of the projects (quite big house in south Kensington) and we are looking for...
