Discuss Underfloor heating query! in the UK Electrical Forum area at ElectriciansForums.net
B
bluefoxfire1234
I'm installing under floor heating on a concrete floor, it will be having wood flooring. Just wondering if I have to enclose the cable in a steel conduit or use armoured? Or if I'd get away with clipping t&e on the floor? Any advice would help. Thanks.
bloody 'ell. this has to be a wind-up. if not, then you need to get someone who knows what the bloody hell they're doing.
lol....lol lol...
anyone knows its an SWA....
you will need a 10mm CSA 3 core...
scratch out a deep enough channel in the concrete wont you...allow a bit more at the ends so you can fly the armourings into a connector block...
Unbelievable.
when clipping t+e to the concrete floor you have to wait for the precise moment, too soft and clip nails will be coming off, too hard will be trouble to nail them in.
Reply to Underfloor heating query! in the UK Electrical Forum area at ElectriciansForums.net
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
I'm after some advice please, I have carbon mat underfloor heating throughout my bungalow, each room has its own thermostat and are fed via a...
Hi, this is a repost of the initial in diy as the only potential diy aspect is the prep ahead of a qualified person attending, this is hopefully...
