Discuss Underfloor heating wiring connection plug in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
5CE94D3A-866C-49B6-8C4F-948F6FAF1AE5.jpegEa
TL;DR
Hello all,
I am wondering if someone can provide me with some advice. I have had underfloor heating installed and there is underfloor heating wiring left behind a socket. What type of plug can I use to connect the underfloor heating wiring to. I have attached a picture for all of you. Thank you!!
If, as I suspect that is electric underfloor heating there should also be a temperature sensor bulb/cable somewhere adjacent to the power feed, if this has not been put in, you will have all sorts of problems trying to control the heating. What make is the UFH, do you have a specification or instruction manual for it?
I suspect the floor tiler has installed the heat mat and just left it like that pending the OP getting a sparks in to complete the job.
As per previous post, doesn't look like a floor sensor cable in the photo.
It needs testing properly to make sure it hasn't been damaged during installation, something a sparks will do before energising, not to mention and isolator and programmer/thermostat controller.
Reply to Underfloor heating wiring connection plug in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi. I'm installing a wet underfloor heating system in my own house. What would you recommend as the best smart control system? I can hardwire...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
