Discuss Unknown socket - help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
tvout
I have the attached socket in a bathroom. I have never seen it before, and cant seem to find a suitable adapter for it. Does anyone know anything about this socket, and where you can find an adapter for it?
nope - its too wide for normal electric shavers (or for an electric toothbrush anyway) - its around an inch wide between the two outer pins
you can still buy them in B&Q today! trust me the answer is on the unit. "Shavers Only";) You don't use the 2 outer pins together, you use the left pin and centre pin for 115v (American) equipment and the right pin and centre pin for 230v equipment (Europe).
ha - i figured that much, i just thought it was an old fashioned style one. what kind of adapter will allow an electric toothbrush to plug into it?
Reply to Unknown socket - help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket, I was gonna put the socket behind...
Hi, I have recently moved in to a house where there is a switch outside the bathroom that controls the power to the shaver socket. Never seen...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
2nd fixing some sockets in an office today and we were talking about high integrity earthing, I've not got a clue what the sockets are going to...
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
