Discuss Unstable voltage affecting bulbs in the UK Electrical Forum area at ElectriciansForums.net
Y
Yirenkyi Samuel
Hi,a member from Ghana
There is this house i just finished wiring and they come to install the meter
Iv realized that,the voltage sometimes rises above 250v so it blows most of the bulbs.
I tested the phases and detected a phase which does not rise above 250v but above 240v
so,I put all the lighting circuits on that particular phase
now most of the bulbs doesn't blow except one circuit, which is closer to the consumer unit. The switch is just beside the consumer unit that is where the circuit starts from.
What should be the cause?
Reply to Unstable voltage affecting bulbs in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I have a regular client who has asked for a battery back up system to be installed at their home. They live in a rural location on a...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I have a 230 Volt single-phase circuit with a 100 Amp cutout fuse and a 100 Amp MCB switch, so the supply is rated at 23 kVA. Only about 13% of...
6K
Hi Im newto this forum and hello to everybody. Im experienced electrician with 15 years of experience in all kind of domestic premised. Some...
6K
Someone asked about abbreviations used here. So I tried to copy a list I made elsewhere: A/C Air Conditioning AC Alternating Current ACB...
5K
