Discuss Upgrading MR16 TO GU10 in the UK Electrical Forum area at ElectriciansForums.net
Regarding the earths I have already checked the current setup and they are still there (connected via a junction box)
Have you tested them properly ........... just because they are there doesn't mean anything.
Those downlights are designed for ise with selv (12v) not 240v imo no you cannot just change the lampholder if the body of the downlight is metalic it not sould be earthed via the cpc. Far simpler/better/safer to install new fire rated led downlights, reccomend tamlight, than p***ing about with the old ones.
It's not the 1st of April yet is it ??
How can you possibly state that? I'm not aware of any photo's and there are downlights on the market with both leads in the packaging.
Whats wrong with tamlight??
If there are downlights on the market with both leads out they must be class 2 fittings. How can i state that, because the body of the standard 12v downlight has not been designed for a 240v lampholder simple.
Reply to Upgrading MR16 TO GU10 in the UK Electrical Forum area at ElectriciansForums.net
